<?xml version="1.0"?>
<api>
  <error code="unknown_action" info="Unrecognized value for parameter &#039;action&#039;: https://totobeam.com/sports_guide/" xml:space="preserve">
                         of "unknown_action".
Parameters:
                            dump, dumpfm, none
                        Default: xmlfm
                        Default: help
                        Default: 0
                        Default: 0
                        One value: user, bot
* action=login (lg) *
  automated password crackers.
Parameters:
Example:
* action=logout *
Example:
  Log the current user out:
    api.php?action=logout
* action=createaccount *
  Create a new user account.
Parameters:
                        This parameter is required
Examples:
* action=query *
Parameters:
                            watchlistraw
                        Separate values with '|'
Examples:
* prop=categories (cl) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* prop=categoryinfo (ci) *
Parameters:
Example:
* prop=contributors (pc) *
Parameters:
                        Default: 10
Example:
* prop=duplicatefiles (df) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* prop=extlinks (el) *
Parameters:
                        Default: 10
                        Default:
Example:
* prop=imageinfo (ii) *
Parameters:
                        Default: timestamp|user
                        Default: 1
                        Default: -1
                        Default: -1
                        Default: 1
                        Default: de
                        Default:
Examples:
* prop=images (im) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* prop=info (in) *
Parameters:
                            displaytitle
Examples:
* prop=iwlinks (iw) *
Parameters:
                        Default: 10
                        Default: ascending
Example:
* prop=langlinks (ll) *
Parameters:
                        Default: 10
                         url      - Adds the full URL
                        Default: ascending
                        Default: de
Example:
* prop=links (pl) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* prop=pageprops (pp) *
Parameters:
Example:
* prop=redirects (rd) *
Parameters:
                        Default: pageid|title
                        Default: 10
Examples:
Generator:
* prop=revisions (rv) *
  Get revision information.
  May be used in several ways:
Parameters:
                        One value: newer, older
                        Default: older
                        diffed against this text
Examples:
* prop=stashimageinfo (sii) *
Parameters:
                            extmetadata, bitdepth
                        Default: timestamp|url
                        Default: -1
                        Default: -1
                        Default:
Examples:
* prop=templates (tl) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* list=allcategories (ac) *
  Enumerate all categories.
Parameters:
                        Default: ascending
                        Default: 10
                        Default:
Examples:
Generator:
* list=allfileusages (af) *
Parameters:
                        Default: title
                        Default: 10
                        Default: ascending
Examples:
  List unique file titles:
Generator:
* list=allimages (ai) *
Parameters:
                        One value: name, timestamp
                        Default: name
                        Default: ascending
                        One value: all, bots, nobots
                        Default: all
                        Default: 10
Examples:
  Simple Use
  Simple Use
  Using as Generator
Generator:
* list=alllinks (al) *
Parameters:
                        Default: title
                        Default: 0
                        Default: 10
                        Default: ascending
Examples:
  List unique linked titles:
Generator:
* list=allpages (ap) *
Parameters:
                        Default: 0
                        Default: all
                        Default: all
                        Default: 10
                        Default: ascending
                        Default: all
                        Default: all
Examples:
  Simple Use
  Using as Generator
Generator:
* list=allredirects (ar) *
Parameters:
                        Default: title
                        Default: 0
                        Default: 10
                        Default: ascending
Examples:
  List unique target pages:
Generator:
Parameters:
                        Default: title
                        Default: 10
                        Default: 10
                        Default: ascending
Examples:
Generator:
* list=allusers (au) *
Parameters:
                        Default: ascending
                        Default: 10
Example:
* list=backlinks (bl) *
Parameters:
                        Default: ascending
                        Default: all
                        Default: 10
Examples:
Generator:
* list=blocks (bk) *
Parameters:
                        Default: older
                        Default: 10
Examples:
* list=categorymembers (cm) *
Parameters:
                        Default: ids|title
                        Default: page|subcat|file
                        Default: 10
                        One value: sortkey, timestamp
                        Default: sortkey
                        Default: ascending
Examples:
Generator:
* list=deletedrevs (dr) *
  List deleted revisions.
  Operates in three modes:
Parameters:
                        Default: older
                        Default: 0
                        Default: 10
                        Default: user|comment
Examples:
* list=embeddedin (ei) *
Parameters:
                        Default: ascending
                        Default: all
                        Default: 10
Examples:
Generator:
* list=exturlusage (eu) *
Parameters:
                         ids    - Adds the ID of page
                        Default: ids|title|url
                        Default:
                        Default: 10
Example:
Generator:
* list=filearchive (fa) *
Parameters:
                        Default: 10
                        Default: ascending
                            bitdepth, archivename
                        Default: timestamp
Example:
  Simple Use
* list=imageusage (iu) *
Parameters:
                        Default: ascending
                        Default: all
                        Default: 10
Examples:
Generator:
* list=iwbacklinks (iwbl) *
Parameters:
                        Default: 10
                        Default:
                        Default: ascending
Examples:
Generator:
* list=langbacklinks (lbl) *
Parameters:
                        Default: 10
                        Default:
                        Default: ascending
Examples:
Generator:
* list=logevents (le) *
  Get events from logs.
Parameters:
                        Default: older
                        Default: 10
Example:
* list=pagepropnames (ppn) *
Parameters:
                        Default: 10
Example:
  Get first 10 prop names:
* list=pageswithprop (pwp) *
Parameters:
                        Default: ids|title
                        Default: 10
                        Default: ascending
Examples:
Generator:
* list=prefixsearch (ps) *
Parameters:
                        Default: 0
                        Default: 10
Example:
Generator:
* list=protectedtitles (pt) *
Parameters:
                        Default: 10
                        Default: older
                        Default: timestamp|level
Example:
Generator:
* list=querypage (qp) *
Parameters:
                        Default: 0
                        Default: 10
Example:
Generator:
* list=random (rn) *
  Get a set of random pages.
Parameters:
                        Default: 1
Example:
Generator:
* list=recentchanges (rc) *
  Enumerate recent changes.
Parameters:
                        Default: older
                            loginfo, tags, sha1
                        Default: title|timestamp|ids
                        Default: 10
Example:
Generator:
* list=search (sr) *
  Perform a full text search.
Parameters:
                        Default: 0
                        Default: totalhits|suggestion
                        Default: 0
                        Default: 10
Examples:
Generator:
* list=tags (tg) *
  List change tags.
Parameters:
                        Default: 10
                        Default: name
Example:
* list=usercontribs (uc) *
  Get all edits by a user.
Parameters:
                        Default: 10
                        Overrides ucuser
                        Default: older
Examples:
* list=users (us) *
Parameters:
Example:
* list=watchlist (wl) *
Parameters:
                        Default: older
                        Default: 10
                        Default: ids|title|flags
                         log            - Log entries
Examples:
Generator:
* list=watchlistraw (wr) *
Parameters:
                        Default: 10
                        Default: ascending
Examples:
Generator:
* meta=allmessages (am) *
Parameters:
                        Separate values with '|'
                        Default: *
                        Default: all
Examples:
* meta=filerepoinfo (fri) *
Parameters:
                            favicon
Example:
* meta=siteinfo (si) *
Parameters:
                        Default: general
                        One value: local, !local
Examples:
* meta=userinfo (ui) *
Parameters:
Examples:
* action=expandtemplates *
Parameters:
                        Default: API
                        This parameter is required
Example:
* action=parse *
Parameters:
                            limitreporthtml
Examples:
  Parse a page:
  Parse wikitext:
  Parse a summary:
* action=opensearch *
Parameters:
                        Default: 10
                        Default: 0
                        One value: json, jsonfm
                        Default: json
Example:
* action=feedcontributions *
Parameters:
                        One value: rss, atom
                        Default: rss
                        Default:
Example:
* action=feedrecentchanges *
  Returns a recent changes feed
Parameters:
                        Default: rss
                        Default: 7
                        Default: 50
Examples:
* action=feedwatchlist *
  Returns a watchlist feed.
Parameters:
                        Default: rss
                        Default: 24
                         log            - Log entries
Examples:
  api.php?action=feedwatchlist
* action=help *
Parameters:
Examples:
  Whole help page:
    api.php?action=help
  Module (action) help page:
* action=paraminfo *
Parameters:
                            xmlfm, yaml, yamlfm
Example:
* action=rsd *
Example:
  api.php?action=rsd
* action=compare *
Parameters:
Example:
* action=tokens *
Parameters:
                        Default: edit
Examples:
    api.php?action=tokens
* action=purge *
Parameters:
Example:
Parameters:
Examples:
* action=rollback *
Parameters:
                        Default:
                        Default: preferences
Examples:
* action=delete *
  Delete a page.
Parameters:
Examples:
  Delete the Main Page:
* action=undelete *
Parameters:
                        Default:
Examples:
* action=protect *
Parameters:
                        Default: infinite
                        Default:
Examples:
* action=block *
  Block a user.
Parameters:
                        Default: never
                        Default:
Examples:
* action=unblock *
  Unblock a user.
Parameters:
                        Default:
Examples:
  api.php?action=unblock&id=105
* action=move *
  Move a page.
Parameters:
                        Default:
Example:
* action=edit *
  Create and edit pages.
Parameters:
Examples:
  Edit a page (anonymous user):
* action=upload *
Parameters:
                        Default:
Examples:
  Upload from a URL:
* action=filerevert *
Parameters:
                        Default:
Example:
* action=emailuser *
  Email a user.
Parameters:
Example:
* action=watch *
Parameters:
Examples:
  Watch the page "Main Page":
  Unwatch the page "Main Page":
* action=patrol *
  Patrol a page or revision.
Parameters:
Examples:
* action=import *
Parameters:
                        One value:
Example:
* action=userrights *
Parameters:
  userid              - User id
                        Default:
Examples:
* action=options *
  scripts), can be set.
Parameters:
                        Default: all
Examples:
* action=imagerotate *
  Rotate one or more images.
Parameters:
                        One value: 90, 180, 270
Example:
* action=revisiondelete *
  Delete/undelete revisions.
Parameters:
                        One value: yes, no, nochange
                        Default: nochange
Examples:
* writeapi *
  Use of the write API
Granted to:
  all, user, bot
* apihighlimits *
Granted to:
  bot, sysop
* format=json *
  Output data in JSON format
Parameters:
Example:
* format=jsonfm *
Parameters:
Example:
* format=php *
Example:
* format=phpfm *
Example:
* format=wddx *
  Output data in WDDX format
Example:
* format=wddxfm *
Example:
* format=xml *
  Output data in XML format
Parameters:
Example:
* format=xmlfm *
Parameters:
Example:
* format=yaml *
  Output data in YAML format
Parameters:
Example:
* format=yamlfm *
Parameters:
Example:
* format=rawfm *
Parameters:
Example:
* format=txt *
Example:
* format=txtfm *
Example:
* format=dbg *
Example:
* format=dbgfm *
Example:
* format=dump *
Example:
* format=dumpfm *
Example:
* format=none *
  Output nothing
Example:
*** Credits: ***
   API developers:
       Victor Vasiliev
       Bryan Tong Minh
       Sam Reed
</error>
</api>
