MediaWiki API
<?xml version="1.0"?>
<api>
<error code="unknown_action" info="Unrecognized value for parameter 'action': https://may.lawhub.ru/masdared-reasade-rewuki-palaharet-yasdeli-polkirat/" xml:space="preserve">
** This is an auto-generated MediaWiki API documentation page **
** Documentation and Examples: **
** https://www.mediawiki.org/wiki/API **
Status: All features shown on this page should be working, but the API
Erroneous requests: When erroneous requests are sent to the API, a HTTP header will be sent
of "unknown_action".
Documentation: https://www.mediawiki.org/wiki/API:Main_page
FAQ https://www.mediawiki.org/wiki/API:FAQ
Mailing list: https://lists.wikimedia.org/mailman/listinfo/mediawiki-api
Api Announcements: https://lists.wikimedia.org/mailman/listinfo/mediawiki-api-announce
Bugs & Requests: https://bugzilla.wikimedia.org/buglist.cgi?component=API&bug_status=NEW&bug_status=ASSIGNED&bug_status=REOPENED&order=bugs.delta_ts
Parameters:
format - The format of the output
dump, dumpfm, none
Default: xmlfm
action - What action you would like to perform. See below for module help
Default: help
maxlag - Maximum lag can be used when MediaWiki is installed on a database replicated cluster.
smaxage - Set the s-maxage header to this many seconds. Errors are never cached
Default: 0
maxage - Set the max-age header to this many seconds. Errors are never cached
Default: 0
assert - Verify the user is logged in if set to "user", or has the bot userright if "bot"
One value: user, bot
requestid - Request ID to distinguish requests. This will just be output back to you
servedby - Include the hostname that served the request in the results. Unconditionally shown on error
origin - When accessing the API using a cross-domain AJAX request (CORS), set this to the
*** *** *** *** *** *** *** *** *** *** *** *** *** *** Modules *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* action=login (lg) *
automated password crackers.
Parameters:
lgname - User Name
lgpassword - Password
lgdomain - Domain (optional)
lgtoken - Login token obtained in first request
Example:
* action=logout *
Example:
Log the current user out:
api.php?action=logout
* action=createaccount *
Create a new user account.
Parameters:
name - Username
This parameter is required
password - Password (ignored if mailpassword is set)
domain - Domain for external authentication (optional)
token - Account creation token obtained in first request
email - Email address of user (optional)
realname - Real name of user (optional)
mailpassword - If set to any value, a random password will be emailed to the user
reason - Optional reason for creating the account to be put in the logs
language - Language code to set as default for the user (optional, defaults to content language)
Examples:
* action=query *
Parameters:
prop - Which properties to get for the titles/revisions/pageids. Module help is available below
list - Which lists to get. Module help is available below
watchlistraw
meta - Which metadata to get about the site. Module help is available below
indexpageids - Include an additional pageids section listing all returned page IDs
export - Export the current revisions of all given or generated pages
exportnowrap - Return the export XML without wrapping it in an XML result (same format as Special:Export). Can only be used with export
iwurl - Whether to get the full URL if the title is an interwiki link
continue - When present, formats query-continue as key-value pairs that should simply be merged into the original request.
titles - A list of titles to work on
Separate values with '|'
pageids - A list of page IDs to work on
revids - A list of revision IDs to work on
redirects - Automatically resolve redirects
converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion.
generator - Get the list of pages to work on by executing the specified query module.
Examples:
--- --- --- --- --- --- --- --- --- --- --- --- Query: Prop --- --- --- --- --- --- --- --- --- --- --- ---
* prop=categories (cl) *
Parameters:
clprop - Which additional properties to get for each category
sortkey - Adds the sortkey (hexadecimal string) and sortkey prefix
timestamp - Adds timestamp of when the category was added
hidden - Tags categories that are hidden with __HIDDENCAT__
clshow - Which kind of categories to show
cllimit - How many categories to return
Default: 10
clcontinue - When more results are available, use this to continue
clcategories - Only list these categories. Useful for checking whether a certain page is in a certain category
cldir - The direction in which to list
Default: ascending
Examples:
Generator:
* prop=categoryinfo (ci) *
Parameters:
cicontinue - When more results are available, use this to continue
Example:
* prop=contributors (pc) *
Parameters:
pcgroup - Limit users to given group name(s)
pcexcludegroup - Exclude users in given group name(s)
pcrights - Limit users to those having given right(s)
pcexcluderights - Limit users to those not having given right(s)
pclimit - How many contributors to return
Default: 10
pccontinue - When more results are available, use this to continue
Example:
* prop=duplicatefiles (df) *
Parameters:
dflimit - How many duplicate files to return
Default: 10
dfcontinue - When more results are available, use this to continue
dfdir - The direction in which to list
Default: ascending
dflocalonly - Look only for files in the local repository
Examples:
Generator:
* prop=extlinks (el) *
Parameters:
ellimit - How many links to return
Default: 10
eloffset - When more results are available, use this to continue
elprotocol - Protocol of the URL. If empty and elquery set, the protocol is http.
Default:
elquery - Search string without protocol. Useful for checking whether a certain page contains a certain external url
elexpandurl - Expand protocol-relative URLs with the canonical protocol
Example:
* prop=imageinfo (ii) *
Parameters:
iiprop - What image information to get:
timestamp - Adds timestamp for the uploaded version
user - Adds the user who uploaded the image version
userid - Add the user ID that uploaded the image version
comment - Comment on the version
url - Gives URL to the image and the description page
size - Adds the size of the image in bytes and the height, width and page count (if applicable)
dimensions - Alias for size
sha1 - Adds SHA-1 hash for the image
mime - Adds MIME type of the image
thumbmime - Adds MIME type of the image thumbnail (requires url and param iiurlwidth)
mediatype - Adds the media type of the image
metadata - Lists Exif metadata for the version of the image
extmetadata - Lists formatted metadata combined from multiple sources. Results are HTML formatted.
archivename - Adds the file name of the archive version for non-latest versions
bitdepth - Adds the bit depth of the version
Default: timestamp|user
iilimit - How many image revisions to return per image
Default: 1
iistart - Timestamp to start listing from
iiend - Timestamp to stop listing at
iiurlwidth - If iiprop=url is set, a URL to an image scaled to this width will be returned.
Default: -1
iiurlheight - Similar to iiurlwidth.
Default: -1
iimetadataversion - Version of metadata to use. if 'latest' is specified, use latest version.
Default: 1
Default: de
iiurlparam - A handler specific parameter string. For example, pdf's
Default:
iicontinue - If the query response includes a continue value, use it here to get another page of results
iilocalonly - Look only for files in the local repository
Examples:
* prop=images (im) *
Parameters:
imlimit - How many images to return
Default: 10
imcontinue - When more results are available, use this to continue
imimages - Only list these images. Useful for checking whether a certain page has a certain Image.
imdir - The direction in which to list
Default: ascending
Examples:
Generator:
* prop=info (in) *
Parameters:
inprop - Which additional properties to get:
protection - List the protection level of each page
talkid - The page ID of the talk page for each non-talk page
watched - List the watched status of each page
watchers - The number of watchers, if allowed
subjectid - The page ID of the parent page for each talk page
url - Gives a full URL to the page, and also an edit URL
readable - Whether the user can read this page
preload - Gives the text returned by EditFormPreloadText
displaytitle - Gives the way the page title is actually displayed
displaytitle
intoken - Request a token to perform a data-modifying action on a page
incontinue - When more results are available, use this to continue
Examples:
* prop=iwlinks (iw) *
Parameters:
iwlimit - How many interwiki links to return
Default: 10
iwcontinue - When more results are available, use this to continue
iwprefix - Prefix for the interwiki
iwtitle - Interwiki link to search for. Must be used with iwprefix
iwdir - The direction in which to list
Default: ascending
Example:
* prop=langlinks (ll) *
Parameters:
lllimit - How many langlinks to return
Default: 10
llcontinue - When more results are available, use this to continue
llurl - DEPRECATED! Whether to get the full URL (Cannot be used with llprop)
llprop - Which additional properties to get for each interlanguage link
url - Adds the full URL
autonym - Adds the native language name
lllang - Language code
lltitle - Link to search for. Must be used with lllang
lldir - The direction in which to list
Default: ascending
llinlanguagecode - Language code for localised language names
Default: de
Example:
* prop=links (pl) *
Parameters:
plnamespace - Show links in this namespace(s) only
pllimit - How many links to return
Default: 10
plcontinue - When more results are available, use this to continue
pltitles - Only list links to these titles. Useful for checking whether a certain page links to a certain title.
pldir - The direction in which to list
Default: ascending
Examples:
Generator:
* prop=pageprops (pp) *
Parameters:
ppcontinue - When more results are available, use this to continue
ppprop - Only list these props. Useful for checking whether a certain page uses a certain page prop
Example:
* prop=redirects (rd) *
Parameters:
rdprop - Which properties to get:
pageid - Page id of each redirect
title - Title of each redirect
Default: pageid|title
rdshow - Show only items that meet this criteria.
fragment - Only show redirects with a fragment
rdlimit - How many redirects to return
Default: 10
rdcontinue - When more results are available, use this to continue
Examples:
Generator:
* prop=revisions (rv) *
Get revision information.
May be used in several ways:
Parameters:
rvprop - Which properties to get for each revision:
ids - The ID of the revision
flags - Revision flags (minor)
timestamp - The timestamp of the revision
user - User that made the revision
userid - User id of revision creator
size - Length (bytes) of the revision
sha1 - SHA-1 (base 16) of the revision
contentmodel - Content model id
comment - Comment by the user for revision
parsedcomment - Parsed comment by the user for the revision
content - Text of the revision
tags - Tags for the revision
rvlimit - Limit how many revisions will be returned (enum)
rvstartid - From which revision id to start enumeration (enum)
rvendid - Stop revision enumeration on this revid (enum)
rvstart - From which revision timestamp to start enumeration (enum)
rvend - Enumerate up to this timestamp (enum)
rvdir - In which direction to enumerate (enum)
newer - List oldest first. Note: rvstart has to be before rvend.
older - List newest first (default). Note: rvstart has to be later than rvend.
One value: newer, older
Default: older
rvuser - Only include revisions made by user (enum)
rvexcludeuser - Exclude revisions made by user (enum)
rvtag - Only list revisions tagged with this tag
rvexpandtemplates - Expand templates in revision content (requires rvprop=content)
rvgeneratexml - Generate XML parse tree for revision content (requires rvprop=content)
rvparse - Parse revision content (requires rvprop=content).
rvsection - Only retrieve the content of this section number
rvtoken - Which tokens to obtain for each revision
rvcontinue - When more results are available, use this to continue
rvdiffto - Revision ID to diff each revision to.
rvdifftotext - Text to diff each revision to. Only diffs a limited number of revisions.
diffed against this text
rvcontentformat - Serialization format used for difftotext and expected for output of content
Examples:
* prop=stashimageinfo (sii) *
Parameters:
siifilekey - Key that identifies a previous upload that was stashed temporarily.
siisessionkey - DEPRECATED! Alias for filekey, for backward compatibility.
siiprop - What image information to get:
thumbmime - Adds MIME type of the image thumbnail (requires url and param siiurlwidth)
extmetadata, bitdepth
Default: timestamp|url
siiurlwidth - If siiprop=url is set, a URL to an image scaled to this width will be returned.
Default: -1
siiurlheight - Similar to siiurlwidth. Cannot be used without siiurlwidth
Default: -1
siiurlparam - A handler specific parameter string. For example, pdf's
Default:
Examples:
* prop=templates (tl) *
Parameters:
tlnamespace - Show templates in this namespace(s) only
tllimit - How many templates to return
Default: 10
tlcontinue - When more results are available, use this to continue
tltemplates - Only list these templates. Useful for checking whether a certain page uses a certain template.
tldir - The direction in which to list
Default: ascending
Examples:
Generator:
--- --- --- --- --- --- --- --- --- --- --- --- Query: List --- --- --- --- --- --- --- --- --- --- --- ---
* list=allcategories (ac) *
Enumerate all categories.
Parameters:
acfrom - The category to start enumerating from
accontinue - When more results are available, use this to continue
acto - The category to stop enumerating at
acprefix - Search for all category titles that begin with this value
acdir - Direction to sort in
Default: ascending
acmin - Minimum number of category members
acmax - Maximum number of category members
aclimit - How many categories to return
Default: 10
acprop - Which properties to get
size - Adds number of pages in the category
Default:
Examples:
Generator:
* list=allfileusages (af) *
Parameters:
afcontinue - When more results are available, use this to continue
affrom - The title of the file to start enumerating from
afto - The title of the file to stop enumerating at
afprefix - Search for all file titles that begin with this value
afunique - Only show distinct file titles. Cannot be used with afprop=ids.
afprop - What pieces of information to include
ids - Adds the pageid of the using page (Cannot be used with afunique)
title - Adds the title of the file
Default: title
aflimit - How many total items to return
Default: 10
afdir - The direction in which to list
Default: ascending
Examples:
List unique file titles:
Generator:
* list=allimages (ai) *
Parameters:
aisort - Property to sort by
One value: name, timestamp
Default: name
aidir - The direction in which to list
Default: ascending
aifrom - The image title to start enumerating from. Can only be used with aisort=name
aito - The image title to stop enumerating at. Can only be used with aisort=name
aicontinue - When more results are available, use this to continue
aistart - The timestamp to start enumerating from. Can only be used with aisort=timestamp
aiend - The timestamp to end enumerating. Can only be used with aisort=timestamp
aiprop - What image information to get:
aiprefix - Search for all image titles that begin with this value. Can only be used with aisort=name
aiminsize - Limit to images with at least this many bytes
aimaxsize - Limit to images with at most this many bytes
aisha1 - SHA1 hash of image. Overrides aisha1base36
aisha1base36 - SHA1 hash of image in base 36 (used in MediaWiki)
aiuser - Only return files uploaded by this user. Can only be used with aisort=timestamp. Cannot be used together with aifilterbots
aifilterbots - How to filter files uploaded by bots. Can only be used with aisort=timestamp. Cannot be used together with aiuser
One value: all, bots, nobots
Default: all
aimime - What MIME type to search for. e.g. image/jpeg. Disabled in Miser Mode
ailimit - How many images in total to return
Default: 10
Examples:
Simple Use
Simple Use
Using as Generator
Generator:
* list=alllinks (al) *
Parameters:
alcontinue - When more results are available, use this to continue
alfrom - The title of the link to start enumerating from
alto - The title of the link to stop enumerating at
alprefix - Search for all linked titles that begin with this value
alunique - Only show distinct linked titles. Cannot be used with alprop=ids.
alprop - What pieces of information to include
ids - Adds the pageid of the linking page (Cannot be used with alunique)
title - Adds the title of the link
Default: title
alnamespace - The namespace to enumerate
Default: 0
allimit - How many total items to return
Default: 10
aldir - The direction in which to list
Default: ascending
Examples:
List unique linked titles:
Generator:
* list=allpages (ap) *
Parameters:
apfrom - The page title to start enumerating from
apcontinue - When more results are available, use this to continue
apto - The page title to stop enumerating at
apprefix - Search for all page titles that begin with this value
apnamespace - The namespace to enumerate
Default: 0
apfilterredir - Which pages to list
Default: all
apminsize - Limit to pages with at least this many bytes
apmaxsize - Limit to pages with at most this many bytes
apprtype - Limit to protected pages only
apprlevel - The protection level (must be used with apprtype= parameter)
apprfiltercascade - Filter protections based on cascadingness (ignored when apprtype isn't set)
Default: all
aplimit - How many total pages to return.
Default: 10
apdir - The direction in which to list
Default: ascending
apfilterlanglinks - Filter based on whether a page has langlinks
Default: all
apprexpiry - Which protection expiry to filter the page on
Default: all
Examples:
Simple Use
Using as Generator
Generator:
* list=allredirects (ar) *
Parameters:
arcontinue - When more results are available, use this to continue
arfrom - The title of the redirect to start enumerating from
arto - The title of the redirect to stop enumerating at
arprefix - Search for all target pages that begin with this value
arunique - Only show distinct target pages. Cannot be used with arprop=ids|fragment|interwiki.
arprop - What pieces of information to include
ids - Adds the pageid of the redirecting page (Cannot be used with arunique)
title - Adds the title of the redirect
Default: title
arnamespace - The namespace to enumerate
Default: 0
arlimit - How many total items to return
Default: 10
ardir - The direction in which to list
Default: ascending
Examples:
List unique target pages:
Generator:
Parameters:
atcontinue - When more results are available, use this to continue
atfrom - The title of the transclusion to start enumerating from
atto - The title of the transclusion to stop enumerating at
atprefix - Search for all transcluded titles that begin with this value
atunique - Only show distinct transcluded titles. Cannot be used with atprop=ids.
atprop - What pieces of information to include
ids - Adds the pageid of the transcluding page (Cannot be used with atunique)
title - Adds the title of the transclusion
Default: title
atnamespace - The namespace to enumerate
Default: 10
atlimit - How many total items to return
Default: 10
atdir - The direction in which to list
Default: ascending
Examples:
Generator:
* list=allusers (au) *
Parameters:
aufrom - The user name to start enumerating from
auto - The user name to stop enumerating at
auprefix - Search for all users that begin with this value
audir - Direction to sort in
Default: ascending
augroup - Limit users to given group name(s)
auexcludegroup - Exclude users in given group name(s)
aurights - Limit users to given right(s) (does not include rights granted by implicit or auto-promoted groups like *, user, or autoconfirmed)
auprop - What pieces of information to include.
blockinfo - Adds the information about a current block on the user
groups - Lists groups that the user is in. This uses more server resources and may return fewer results than the limit
rights - Lists rights that the user has
editcount - Adds the edit count of the user
registration - Adds the timestamp of when the user registered if available (may be blank)
aulimit - How many total user names to return
Default: 10
auwitheditsonly - Only list users who have made edits
auactiveusers - Only list users active in the last 30 days(s)
Example:
* list=backlinks (bl) *
Parameters:
bltitle - Title to search. Cannot be used together with blpageid
blpageid - Pageid to search. Cannot be used together with bltitle
blcontinue - When more results are available, use this to continue
blnamespace - The namespace to enumerate
bldir - The direction in which to list
Default: ascending
blfilterredir - How to filter for redirects. If set to nonredirects when blredirect is enabled, this is only applied to the second level
Default: all
bllimit - How many total pages to return. If blredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results).
Default: 10
blredirect - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved.
Examples:
Generator:
* list=blocks (bk) *
Parameters:
bkstart - The timestamp to start enumerating from
bkend - The timestamp to stop enumerating at
bkdir - In which direction to enumerate
newer - List oldest first. Note: bkstart has to be before bkend.
older - List newest first (default). Note: bkstart has to be later than bkend.
Default: older
bkids - List of block IDs to list (optional)
bkusers - List of users to search for (optional)
bkip - Get all blocks applying to this IP or CIDR range, including range blocks.
bklimit - The maximum amount of blocks to list
Default: 10
bkprop - Which properties to get
id - Adds the ID of the block
user - Adds the username of the blocked user
userid - Adds the user ID of the blocked user
by - Adds the username of the blocking user
byid - Adds the user ID of the blocking user
timestamp - Adds the timestamp of when the block was given
expiry - Adds the timestamp of when the block expires
reason - Adds the reason given for the block
range - Adds the range of IPs affected by the block
flags - Tags the ban with (autoblock, anononly, etc)
bkshow - Show only items that meet this criteria.
bkcontinue - When more results are available, use this to continue
Examples:
* list=categorymembers (cm) *
Parameters:
cmtitle - Which category to enumerate (required). Must include 'Category:' prefix. Cannot be used together with cmpageid
cmpageid - Page ID of the category to enumerate. Cannot be used together with cmtitle
cmprop - What pieces of information to include
ids - Adds the page ID
title - Adds the title and namespace ID of the page
sortkey - Adds the sortkey used for sorting in the category (hexadecimal string)
type - Adds the type that the page has been categorised as (page, subcat or file)
timestamp - Adds the timestamp of when the page was included
Default: ids|title
cmnamespace - Only include pages in these namespaces
cmtype - What type of category members to include. Ignored when cmsort=timestamp is set
Default: page|subcat|file
cmcontinue - For large categories, give the value returned from previous query
cmlimit - The maximum number of pages to return.
Default: 10
cmsort - Property to sort by
One value: sortkey, timestamp
Default: sortkey
cmdir - In which direction to sort
Default: ascending
cmstart - Timestamp to start listing from. Can only be used with cmsort=timestamp
cmend - Timestamp to end listing at. Can only be used with cmsort=timestamp
cmstartsortkey - Sortkey to start listing from. Must be given in binary format. Can only be used with cmsort=sortkey
cmendsortkey - Sortkey to end listing at. Must be given in binary format. Can only be used with cmsort=sortkey
cmendsortkeyprefix - Sortkey prefix to end listing BEFORE (not at, if this value occurs it will not be included!). Can only be used with cmsort=sortkey. Overrides cmendsortkey
Examples:
Generator:
* list=deletedrevs (dr) *
List deleted revisions.
Operates in three modes:
Parameters:
drstart - The timestamp to start enumerating from (1, 2)
drend - The timestamp to stop enumerating at (1, 2)
drdir - In which direction to enumerate (1, 3)
newer - List oldest first. Note: drstart has to be before drend.
older - List newest first (default). Note: drstart has to be later than drend.
Default: older
drfrom - Start listing at this title (3)
drto - Stop listing at this title (3)
drprefix - Search for all page titles that begin with this value (3)
drcontinue - When more results are available, use this to continue
drunique - List only one revision for each page (3)
drtag - Only list revisions tagged with this tag
druser - Only list revisions by this user
drexcludeuser - Don't list revisions by this user
drnamespace - Only list pages in this namespace (3)
Default: 0
drlimit - The maximum amount of revisions to list
Default: 10
drprop - Which properties to get
revid - Adds the revision ID of the deleted revision
parentid - Adds the revision ID of the previous revision to the page
user - Adds the user who made the revision
userid - Adds the user ID whom made the revision
comment - Adds the comment of the revision
parsedcomment - Adds the parsed comment of the revision
minor - Tags if the revision is minor
len - Adds the length (bytes) of the revision
sha1 - Adds the SHA-1 (base 16) of the revision
content - Adds the content of the revision
token - Gives the edit token
Default: user|comment
Examples:
* list=embeddedin (ei) *
Parameters:
eititle - Title to search. Cannot be used together with eipageid
eipageid - Pageid to search. Cannot be used together with eititle
eicontinue - When more results are available, use this to continue
einamespace - The namespace to enumerate
eidir - The direction in which to list
Default: ascending
eifilterredir - How to filter for redirects
Default: all
eilimit - How many total pages to return
Default: 10
Examples:
Generator:
* list=exturlusage (eu) *
Parameters:
euprop - What pieces of information to include
ids - Adds the ID of page
url - Adds the URL used in the page
Default: ids|title|url
euoffset - Used for paging. Use the value returned for "continue"
euprotocol - Protocol of the URL. If empty and euquery set, the protocol is http.
Default:
euquery - Search string without protocol. See [[Special:LinkSearch]]. Leave empty to list all external links
eunamespace - The page namespace(s) to enumerate.
eulimit - How many pages to return.
Default: 10
euexpandurl - Expand protocol-relative URLs with the canonical protocol
Example:
Generator:
* list=filearchive (fa) *
Parameters:
fafrom - The image title to start enumerating from
facontinue - When more results are available, use this to continue
fato - The image title to stop enumerating at
faprefix - Search for all image titles that begin with this value
falimit - How many images to return in total
Default: 10
fadir - The direction in which to list
Default: ascending
fasha1 - SHA1 hash of image. Overrides fasha1base36
fasha1base36 - SHA1 hash of image in base 36 (used in MediaWiki)
faprop - What image information to get:
user - Adds user who uploaded the image version
description - Adds description the image version
mime - Adds MIME of the image
bitdepth, archivename
Default: timestamp
Example:
Simple Use
* list=imageusage (iu) *
Parameters:
iutitle - Title to search. Cannot be used together with iupageid
iupageid - Pageid to search. Cannot be used together with iutitle
iucontinue - When more results are available, use this to continue
iunamespace - The namespace to enumerate
iudir - The direction in which to list
Default: ascending
iufilterredir - How to filter for redirects. If set to nonredirects when iuredirect is enabled, this is only applied to the second level
Default: all
iulimit - How many total pages to return. If iuredirect is enabled, limit applies to each level separately (which means you may get up to 2 * limit results).
Default: 10
iuredirect - If linking page is a redirect, find all pages that link to that redirect as well. Maximum limit is halved.
Examples:
Generator:
* list=iwbacklinks (iwbl) *
Parameters:
iwblprefix - Prefix for the interwiki
iwbltitle - Interwiki link to search for. Must be used with iwblprefix
iwblcontinue - When more results are available, use this to continue
iwbllimit - How many total pages to return
Default: 10
iwblprop - Which properties to get
iwprefix - Adds the prefix of the interwiki
iwtitle - Adds the title of the interwiki
Default:
iwbldir - The direction in which to list
Default: ascending
Examples:
Generator:
* list=langbacklinks (lbl) *
Parameters:
lbllang - Language for the language link
lbltitle - Language link to search for. Must be used with lbllang
lblcontinue - When more results are available, use this to continue
lbllimit - How many total pages to return
Default: 10
lblprop - Which properties to get
lllang - Adds the language code of the language link
lltitle - Adds the title of the language link
Default:
lbldir - The direction in which to list
Default: ascending
Examples:
Generator:
* list=logevents (le) *
Get events from logs.
Parameters:
leprop - Which properties to get
ids - Adds the ID of the log event
title - Adds the title of the page for the log event
type - Adds the type of log event
user - Adds the user responsible for the log event
userid - Adds the user ID who was responsible for the log event
timestamp - Adds the timestamp for the event
comment - Adds the comment of the event
parsedcomment - Adds the parsed comment of the event
details - Lists additional details about the event
tags - Lists tags for the event
letype - Filter log entries to only this type
leaction - Filter log actions to only this action. Overrides letype
lestart - The timestamp to start enumerating from
leend - The timestamp to end enumerating
ledir - In which direction to enumerate
newer - List oldest first. Note: lestart has to be before leend.
older - List newest first (default). Note: lestart has to be later than leend.
Default: older
leuser - Filter entries to those made by the given user
letitle - Filter entries to those related to a page
leprefix - Filter entries that start with this prefix. Disabled in Miser Mode
letag - Only list event entries tagged with this tag
lelimit - How many total event entries to return
Default: 10
lecontinue - When more results are available, use this to continue
Example:
* list=pagepropnames (ppn) *
Parameters:
ppncontinue - When more results are available, use this to continue
ppnlimit - The maximum number of pages to return
Default: 10
Example:
Get first 10 prop names:
* list=pageswithprop (pwp) *
Parameters:
pwppropname - Page prop for which to enumerate pages
pwpprop - What pieces of information to include
Default: ids|title
pwpcontinue - When more results are available, use this to continue
pwplimit - The maximum number of pages to return
Default: 10
pwpdir - In which direction to sort
Default: ascending
Examples:
Generator:
* list=prefixsearch (ps) *
Parameters:
pssearch - Search string
psnamespace - Namespaces to search
Default: 0
pslimit - Maximum amount of results to return
Default: 10
Example:
Generator:
* list=protectedtitles (pt) *
Parameters:
ptnamespace - Only list titles in these namespaces
ptlevel - Only list titles with these protection levels
ptlimit - How many total pages to return
Default: 10
ptdir - In which direction to enumerate
newer - List oldest first. Note: ptstart has to be before ptend.
older - List newest first (default). Note: ptstart has to be later than ptend.
Default: older
ptstart - Start listing at this protection timestamp
ptend - Stop listing at this protection timestamp
ptprop - Which properties to get
timestamp - Adds the timestamp of when protection was added
user - Adds the user that added the protection
userid - Adds the user id that added the protection
comment - Adds the comment for the protection
parsedcomment - Adds the parsed comment for the protection
expiry - Adds the timestamp of when the protection will be lifted
level - Adds the protection level
Default: timestamp|level
ptcontinue - When more results are available, use this to continue
Example:
Generator:
* list=querypage (qp) *
Parameters:
qppage - The name of the special page. Note, this is case sensitive
qpoffset - When more results are available, use this to continue
Default: 0
qplimit - Number of results to return
Default: 10
Example:
Generator:
* list=random (rn) *
Get a set of random pages.
Parameters:
rnnamespace - Return pages in these namespaces only
rnlimit - Limit how many random pages will be returned
Default: 1
rnredirect - Load a random redirect instead of a random page
Example:
Generator:
* list=recentchanges (rc) *
Enumerate recent changes.
Parameters:
rcstart - The timestamp to start enumerating from
rcend - The timestamp to end enumerating
rcdir - In which direction to enumerate
newer - List oldest first. Note: rcstart has to be before rcend.
older - List newest first (default). Note: rcstart has to be later than rcend.
Default: older
rcnamespace - Filter log entries to only this namespace(s)
rcuser - Only list changes by this user
rcexcludeuser - Don't list changes by this user
rctag - Only list changes tagged with this tag
rcprop - Include additional pieces of information
user - Adds the user responsible for the edit and tags if they are an IP
userid - Adds the user id responsible for the edit
comment - Adds the comment for the edit
parsedcomment - Adds the parsed comment for the edit
flags - Adds flags for the edit
timestamp - Adds timestamp of the edit
title - Adds the page title of the edit
ids - Adds the page ID, recent changes ID and the new and old revision ID
sizes - Adds the new and old page length in bytes
redirect - Tags edit if page is a redirect
patrolled - Tags patrollable edits as being patrolled or unpatrolled
loginfo - Adds log information (logid, logtype, etc) to log entries
tags - Lists tags for the entry
sha1 - Adds the content checksum for entries associated with a revision
loginfo, tags, sha1
Default: title|timestamp|ids
rctoken - Which tokens to obtain for each change
rcshow - Show only items that meet this criteria.
rclimit - How many total changes to return
Default: 10
rctype - Which types of changes to show
rctoponly - Only list changes which are the latest revision
rccontinue - When more results are available, use this to continue
Example:
Generator:
* list=search (sr) *
Perform a full text search.
Parameters:
srsearch - Search for all page titles (or content) that has this value
srnamespace - The namespace(s) to enumerate
Default: 0
srwhat - Search inside the text or titles
srinfo - What metadata to return
Default: totalhits|suggestion
srprop - What properties to return
size - Adds the size of the page in bytes
wordcount - Adds the word count of the page
timestamp - Adds the timestamp of when the page was last edited
score - Adds the score (if any) from the search engine
snippet - Adds a parsed snippet of the page
titlesnippet - Adds a parsed snippet of the page title
redirectsnippet - Adds a parsed snippet of the redirect title
redirecttitle - Adds the title of the matching redirect
sectionsnippet - Adds a parsed snippet of the matching section title
sectiontitle - Adds the title of the matching section
hasrelated - Indicates whether a related search is available
sroffset - Use this value to continue paging (return by query)
Default: 0
srlimit - How many total pages to return
Default: 10
srinterwiki - Include interwiki results in the search, if available
Examples:
Generator:
* list=tags (tg) *
List change tags.
Parameters:
tgcontinue - When more results are available, use this to continue
tglimit - The maximum number of tags to list
Default: 10
tgprop - Which properties to get
name - Adds name of tag
displayname - Adds system message for the tag
description - Adds description of the tag
hitcount - Adds the amount of revisions that have this tag
Default: name
Example:
* list=usercontribs (uc) *
Get all edits by a user.
Parameters:
uclimit - The maximum number of contributions to return
Default: 10
ucstart - The start timestamp to return from
ucend - The end timestamp to return to
uccontinue - When more results are available, use this to continue
ucuser - The users to retrieve contributions for
ucuserprefix - Retrieve contributions for all users whose names begin with this value.
Overrides ucuser
ucdir - In which direction to enumerate
newer - List oldest first. Note: ucstart has to be before ucend.
older - List newest first (default). Note: ucstart has to be later than ucend.
Default: older
ucnamespace - Only list contributions in these namespaces
ucprop - Include additional pieces of information
ids - Adds the page ID and revision ID
timestamp - Adds the timestamp of the edit
comment - Adds the comment of the edit
parsedcomment - Adds the parsed comment of the edit
size - Adds the new size of the edit
sizediff - Adds the size delta of the edit against its parent
flags - Adds flags of the edit
patrolled - Tags patrolled edits
tags - Lists tags for the edit
ucshow - Show only items that meet thse criteria, e.g. non minor edits only: ucshow=!minor
uctag - Only list revisions tagged with this tag
uctoponly - DEPRECATED! Only list changes which are the latest revision
Examples:
* list=users (us) *
Parameters:
usprop - What pieces of information to include
blockinfo - Tags if the user is blocked, by whom, and for what reason
groups - Lists all the groups the user(s) belongs to
rights - Lists all the rights the user(s) has
editcount - Adds the user's edit count
registration - Adds the user's registration timestamp
emailable - Tags if the user can and wants to receive email through [[Special:Emailuser]]
gender - Tags the gender of the user. Returns "male", "female", or "unknown"
ususers - A list of users to obtain the same information for
ustoken - Which tokens to obtain for each user
Example:
* list=watchlist (wl) *
Parameters:
wlallrev - Include multiple revisions of the same page within given timeframe
wlstart - The timestamp to start enumerating from
wlend - The timestamp to end enumerating
wlnamespace - Filter changes to only the given namespace(s)
wluser - Only list changes by this user
wlexcludeuser - Don't list changes by this user
wldir - In which direction to enumerate
newer - List oldest first. Note: wlstart has to be before wlend.
older - List newest first (default). Note: wlstart has to be later than wlend.
Default: older
wllimit - How many total results to return per request
Default: 10
wlprop - Which additional items to get (non-generator mode only).
ids - Adds revision ids and page ids
title - Adds title of the page
user - Adds the user who made the edit
userid - Adds user id of whom made the edit
comment - Adds comment of the edit
parsedcomment - Adds parsed comment of the edit
patrol - Tags edits that are patrolled
sizes - Adds the old and new lengths of the page
notificationtimestamp - Adds timestamp of when the user was last notified about the edit
loginfo - Adds log information where appropriate
Default: ids|title|flags
wlshow - Show only items that meet this criteria.
wltype - Which types of changes to show
edit - Regular page edits
external - External changes
new - Page creations
log - Log entries
wlowner - The name of the user whose watchlist you'd like to access
wltoken - Give a security token (settable in preferences) to allow access to another user's watchlist
wlcontinue - When more results are available, use this to continue
Examples:
Generator:
* list=watchlistraw (wr) *
Parameters:
wrcontinue - When more results are available, use this to continue
wrnamespace - Only list pages in the given namespace(s)
wrlimit - How many total results to return per request
Default: 10
wrprop - Which additional properties to get (non-generator mode only)
changed - Adds timestamp of when the user was last notified about the edit
wrshow - Only list items that meet these criteria
wrowner - The name of the user whose watchlist you'd like to access
wrtoken - Give a security token (settable in preferences) to allow access to another user's watchlist
wrdir - Direction to sort the titles and namespaces in
Default: ascending
Examples:
Generator:
--- --- --- --- --- --- --- --- --- --- --- --- Query: Meta --- --- --- --- --- --- --- --- --- --- --- ---
* meta=allmessages (am) *
Parameters:
ammessages - Which messages to output. "*" (default) means all messages
Separate values with '|'
Default: *
amprop - Which properties to get
amenableparser - Set to enable parser, will preprocess the wikitext of message
amnocontent - If set, do not include the content of the messages in the output.
amincludelocal - Also include local messages, i.e. messages that don't exist in the software but do exist as a MediaWiki: page.
amargs - Arguments to be substituted into message
amfilter - Return only messages with names that contain this string
amcustomised - Return only messages in this customisation state
Default: all
amlang - Return messages in this language
amfrom - Return messages starting at this message
amto - Return messages ending at this message
amtitle - Page name to use as context when parsing message (for enableparser option)
amprefix - Return messages with this prefix
Examples:
api.php?action=query&meta=allmessages&refix=ipb-
* meta=filerepoinfo (fri) *
Parameters:
friprop - Which repository properties to get (there may be more available on some wikis):
apiurl - URL to the repository API - helpful for getting image info from the host.
name - The key of the repository - used in e.g. $wgForeignFileRepos and imageinfo return values.
rooturl - Root URL for image paths.
local - Whether that repository is the local one or not.
favicon
Example:
* meta=siteinfo (si) *
Parameters:
siprop - Which sysinfo properties to get:
general - Overall system information
namespaces - List of registered namespaces and their canonical names
namespacealiases - List of registered namespace aliases
specialpagealiases - List of special page aliases
magicwords - List of magic words and their aliases
statistics - Returns site statistics
interwikimap - Returns interwiki map (optionally filtered, (optionally localised by using siinlanguagecode))
dbrepllag - Returns database server with the highest replication lag
usergroups - Returns user groups and the associated permissions
extensions - Returns extensions installed on the wiki
fileextensions - Returns list of file extensions allowed to be uploaded
rightsinfo - Returns wiki rights (license) information if available
restrictions - Returns information on available restriction (protection) types
languages - Returns a list of languages MediaWiki supports(optionally localised by using siinlanguagecode)
skins - Returns a list of all enabled skins
extensiontags - Returns a list of parser extension tags
functionhooks - Returns a list of parser function hooks
showhooks - Returns a list of all subscribed hooks (contents of $wgHooks)
variables - Returns a list of variable IDs
protocols - Returns a list of protocols that are allowed in external links.
defaultoptions - Returns the default values for user preferences.
Default: general
sifilteriw - Return only local or only nonlocal entries of the interwiki map
One value: local, !local
sishowalldb - List all database servers, not just the one lagging the most
sinumberingroup - Lists the number of users in user groups
siinlanguagecode - Language code for localised language names (best effort, use CLDR extension)
Examples:
* meta=userinfo (ui) *
Parameters:
uiprop - What pieces of information to include
blockinfo - Tags if the current user is blocked, by whom, and for what reason
hasmsg - Adds a tag "message" if the current user has pending messages
groups - Lists all the groups the current user belongs to
implicitgroups - Lists all the groups the current user is automatically a member of
rights - Lists all the rights the current user has
options - Lists all preferences the current user has set
editcount - Adds the current user's edit count
ratelimits - Lists all rate limits applying to the current user
realname - Adds the user's real name
email - Adds the user's email address and email authentication date
acceptlang - Echoes the Accept-Language header sent by the client in a structured format
Examples:
*** *** *** *** *** *** *** *** *** *** *** *** *** *** Modules: continuation *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* action=expandtemplates *
Parameters:
title - Title of page
Default: API
text - Wikitext to convert
This parameter is required
includecomments - Whether to include HTML comments in the output
Example:
* action=parse *
Parameters:
title - Title of page the text belongs to. If omitted, contentmodel must be specified, and "API" will be used as the title
text - Text to parse. Use title or contentmodel to control the content model
summary - Summary to parse
page - Parse the content of this page. Cannot be used together with text and title
pageid - Parse the content of this page. Overrides page
redirects - If the page or the pageid parameter is set to a redirect, resolve it
oldid - Parse the content of this revision. Overrides page and pageid
prop - Which pieces of information to get
text - Gives the parsed text of the wikitext
langlinks - Gives the language links in the parsed wikitext
categories - Gives the categories in the parsed wikitext
languageshtml - DEPRECATED. Will be removed in MediaWiki 1.24.
links - Gives the internal links in the parsed wikitext
templates - Gives the templates in the parsed wikitext
images - Gives the images in the parsed wikitext
externallinks - Gives the external links in the parsed wikitext
sections - Gives the sections in the parsed wikitext
revid - Adds the revision ID of the parsed page
displaytitle - Adds the title of the parsed wikitext
headitems - Gives items to put in the <head> of the page
headhtml - Gives parsed <head> of the page
iwlinks - Gives interwiki links in the parsed wikitext
wikitext - Gives the original wikitext that was parsed
properties - Gives various properties defined in the parsed wikitext
limitreporthtml
pst - Do a pre-save transform on the input before parsing it
onlypst - Do a pre-save transform (PST) on the input, but don't parse it
effectivelanglinks - Includes language links supplied by extensions
uselang - Which language to parse the request in
disablepp - Disable the PP Report from the parser output
generatexml - Generate XML parse tree (requires contentmodel=wikitext)
preview - Parse in preview mode
sectionpreview - Parse in section preview mode (enables preview mode too)
disabletoc - Disable table of contents in output
contentformat - Content serialization format used for the input text
contentmodel - Content model of the input text. If omitted, title must be specified, and default will be the model of the specified title
Examples:
Parse a page:
Parse wikitext:
Parse a summary:
* action=opensearch *
Parameters:
Default: 10
Default: 0
suggest - Do nothing if $wgEnableOpenSearchSuggest is false
format - The format of the output
One value: json, jsonfm
Default: json
Example:
* action=feedcontributions *
Parameters:
feedformat - The format of the feed
One value: rss, atom
Default: rss
user - What users to get the contributions for
namespace - What namespace to filter the contributions by
year - From year (and earlier)
month - From month (and earlier)
tagfilter - Filter contributions that have these tags
Default:
deletedonly - Show only deleted contributions
toponly - Only show edits that are latest revisions
newonly - Only show edits that are page creations
showsizediff - Show the size difference between revisions. Disabled in Miser Mode
Example:
* action=feedrecentchanges *
Returns a recent changes feed
Parameters:
Default: rss
namespace - Namespace to limit the results to
invert - All namespaces but the selected one
associated - Include associated (talk or main) namespace
days - Days to limit the results to
Default: 7
limit - Maximum number of results to return
Default: 50
from - Show changes since then
hideminor - Hide minor changes
hidebots - Hide changes made by bots
hideanons - Hide changes made by anonymous users
hideliu - Hide changes made by registered users
hidepatrolled - Hide patrolled changes
hidemyself - Hide changes made by yourself
tagfilter - Filter by tag
target - Show only changes on pages linked from this page
showlinkedto - Show changes on pages linked to the selected page instead
Examples:
* action=feedwatchlist *
Returns a watchlist feed.
Parameters:
Default: rss
hours - List pages modified within this many hours from now
Default: 24
linktodiffs - Link to change differences instead of article pages
linktosections - Link directly to changed sections if possible
log - Log entries
Examples:
api.php?action=feedwatchlist
* action=help *
Parameters:
modules - List of module names (value of the action= parameter). Can specify submodules with a '+'
querymodules - DEPRECATED! Use modules=query+value instead. List of query module names (value of prop=, meta= or list= parameter)
Examples:
Whole help page:
api.php?action=help
Module (action) help page:
* action=paraminfo *
Parameters:
querymodules - List of query module names (value of prop=, meta= or list= parameter)
mainmodule - Get information about the main (top-level) module as well
pagesetmodule - Get information about the pageset module (providing titles= and friends) as well
formatmodules - List of format module names (value of format= parameter)
xmlfm, yaml, yamlfm
Example:
* action=rsd *
Example:
api.php?action=rsd
* action=compare *
Parameters:
fromtitle - First title to compare
fromid - First page ID to compare
fromrev - First revision to compare
totitle - Second title to compare
toid - Second page ID to compare
torev - Second revision to compare
Example:
* action=tokens *
Parameters:
type - Type of token(s) to request
Default: edit
Examples:
api.php?action=tokens
* action=purge *
Parameters:
forcelinkupdate - Update the links tables
titles - A list of titles to work on
pageids - A list of page IDs to work on
revids - A list of revision IDs to work on
redirects - Automatically resolve redirects
converttitles - Convert titles to other variants if necessary. Only works if the wiki's content language supports variant conversion.
generator - Get the list of pages to work on by executing the specified query module.
Example:
Parameters:
entirewatchlist - Work on all watched pages
token - A token previously acquired via prop=info
timestamp - Timestamp to which to set the notification timestamp
torevid - Revision to set the notification timestamp to (one page only)
newerthanrevid - Revision to set the notification timestamp newer than (one page only)
Examples:
api.php?action=setnotificationtimestamp&titles=Main_page×tamp=2012-01-01T00:00:00Z&token=123ABC
* action=rollback *
Parameters:
title - Title of the page you want to rollback.
user - Name of the user whose edits are to be rolled back. If set incorrectly, you'll get a badtoken error.
token - A rollback token previously retrieved through prop=revisions
summary - Custom edit summary. If empty, default summary will be used
Default:
markbot - Mark the reverted edits and the revert as bot edits
watchlist - Unconditionally add or remove the page from your watchlist, use preferences or do not change watch
Default: preferences
Examples:
* action=delete *
Delete a page.
Parameters:
title - Title of the page you want to delete. Cannot be used together with pageid
pageid - Page ID of the page you want to delete. Cannot be used together with title
token - A delete token previously retrieved through prop=info
reason - Reason for the deletion. If not set, an automatically generated reason will be used
watch - DEPRECATED! Add the page to your watchlist
unwatch - DEPRECATED! Remove the page from your watchlist
oldimage - The name of the old image to delete as provided by iiprop=archivename
Examples:
Delete the Main Page:
* action=undelete *
Parameters:
title - Title of the page you want to restore
token - An undelete token previously retrieved through list=deletedrevs
reason - Reason for restoring
Default:
timestamps - Timestamps of the revisions to restore. If not set, all revisions will be restored.
Examples:
api.php?action=undelete&title=Main%20Page&token=123ABC×tamps=20070703220045|20070702194856
* action=protect *
Parameters:
title - Title of the page you want to (un)protect. Cannot be used together with pageid
pageid - ID of the page you want to (un)protect. Cannot be used together with title
token - A protect token previously retrieved through prop=info
protections - List of protection levels, formatted action=group (e.g. edit=sysop)
expiry - Expiry timestamps. If only one timestamp is set, it'll be used for all protections.
Default: infinite
reason - Reason for (un)protecting
Default:
cascade - Enable cascading protection (i.e. protect pages included in this page)
watch - DEPRECATED! If set, add the page being (un)protected to your watchlist
Examples:
* action=block *
Block a user.
Parameters:
user - Username, IP address or IP range you want to block
token - A block token previously obtained through prop=info
expiry - Relative expiry time, e.g. '5 months' or '2 weeks'. If set to 'infinite', 'indefinite' or 'never', the block will never expire.
Default: never
reason - Reason for block
Default:
anononly - Block anonymous users only (i.e. disable anonymous edits for this IP)
nocreate - Prevent account creation
autoblock - Automatically block the last used IP address, and any subsequent IP addresses they try to login from
noemail - Prevent user from sending email through the wiki. (Requires the "blockemail" right.)
hidename - Hide the username from the block log. (Requires the "hideuser" right.)
allowusertalk - Allow the user to edit their own talk page (depends on $wgBlockAllowsUTEdit)
reblock - If the user is already blocked, overwrite the existing block
watchuser - Watch the user/IP's user and talk pages
Examples:
* action=unblock *
Unblock a user.
Parameters:
id - ID of the block you want to unblock (obtained through list=blocks). Cannot be used together with user
user - Username, IP address or IP range you want to unblock. Cannot be used together with id
token - An unblock token previously obtained through prop=info
reason - Reason for unblock
Default:
Examples:
api.php?action=unblock&id=105
* action=move *
Move a page.
Parameters:
from - Title of the page you want to move. Cannot be used together with fromid
fromid - Page ID of the page you want to move. Cannot be used together with from
to - Title you want to rename the page to
token - A move token previously retrieved through prop=info
reason - Reason for the move
Default:
movetalk - Move the talk page, if it exists
movesubpages - Move subpages, if applicable
noredirect - Don't create a redirect
watch - DEPRECATED! Add the page and the redirect to your watchlist
unwatch - DEPRECATED! Remove the page and the redirect from your watchlist
ignorewarnings - Ignore any warnings
Example:
* action=edit *
Create and edit pages.
Parameters:
title - Title of the page you want to edit. Cannot be used together with pageid
pageid - Page ID of the page you want to edit. Cannot be used together with title
section - Section number. 0 for the top section, 'new' for a new section
sectiontitle - The title for a new section
text - Page content
token - Edit token. You can get one of these through prop=info.
summary - Edit summary. Also section title when section=new and sectiontitle is not set
minor - Minor edit
notminor - Non-minor edit
bot - Mark this edit as bot
basetimestamp - Timestamp of the base revision (obtained through prop=revisions&rvprop=timestamp).
starttimestamp - Timestamp when you obtained the edit token.
recreate - Override any errors about the article having been deleted in the meantime
createonly - Don't edit the page if it exists already
nocreate - Throw an error if the page doesn't exist
md5 - The MD5 hash of the text parameter, or the prependtext and appendtext parameters concatenated.
prependtext - Add this text to the beginning of the page. Overrides text
appendtext - Add this text to the end of the page. Overrides text.
undo - Undo this revision. Overrides text, prependtext and appendtext
undoafter - Undo all revisions from undo to this one. If not set, just undo one revision
redirect - Automatically resolve redirects
contentmodel - Content model of the new content
Examples:
Edit a page (anonymous user):
* action=upload *
Parameters:
filename - Target filename
comment - Upload comment. Also used as the initial page text for new files if "text" is not specified
Default:
text - Initial page text for new files
watch - DEPRECATED! Watch the page
file - File contents
url - URL to fetch the file from
filekey - Key that identifies a previous upload that was stashed temporarily.
sessionkey - DEPRECATED! Same as filekey, maintained for backward compatibility.
stash - If set, the server will not add the file to the repository and stash it temporarily.
filesize - Filesize of entire upload
offset - Offset of chunk in bytes
chunk - Chunk contents
async - Make potentially large file operations asynchronous when possible
asyncdownload - Make fetching a URL asynchronous
leavemessage - If asyncdownload is used, leave a message on the user talk page if finished
statuskey - Fetch the upload status for this file key (upload by URL)
checkstatus - Only fetch the upload status for the given file key
Examples:
Upload from a URL:
* action=filerevert *
Parameters:
filename - Target filename without the File: prefix
Default:
archivename - Archive name of the revision to revert to
Example:
* action=emailuser *
Email a user.
Parameters:
target - User to send email to
subject - Subject header
text - Mail body
ccme - Send a copy of this mail to me
Example:
* action=watch *
Parameters:
title - DEPRECATED! The page to (un)watch. use titles instead
unwatch - If set the page will be unwatched rather than watched
uselang - Language to show the message in
Examples:
Watch the page "Main Page":
Unwatch the page "Main Page":
* action=patrol *
Patrol a page or revision.
Parameters:
token - Patrol token obtained from list=recentchanges
rcid - Recentchanges ID to patrol
revid - Revision ID to patrol
Examples:
* action=import *
Parameters:
token - Import token obtained through prop=info
summary - Import summary
xml - Uploaded XML file
interwikisource - For interwiki imports: wiki to import from
One value:
interwikipage - For interwiki imports: page to import
fullhistory - For interwiki imports: import the full history, not just the current version
templates - For interwiki imports: import all included templates as well
namespace - For interwiki imports: import to this namespace
rootpage - Import as subpage of this page
Example:
* action=userrights *
Parameters:
user - User name
userid - User id
add - Add the user to these groups
remove - Remove the user from these groups
token - A userrights token previously retrieved through list=users
reason - Reason for the change
Default:
Examples:
* action=options *
scripts), can be set.
Parameters:
token - An options token previously obtained through the action=tokens
reset - Resets preferences to the site defaults
resetkinds - List of types of options to reset when the "reset" option is set
Default: all
change - List of changes, formatted name=value (e.g. skin=vector), value cannot contain pipe characters. If no value is given (not
optionname - A name of a option which should have an optionvalue set
optionvalue - A value of the option specified by the optionname, can contain pipe characters
Examples:
* action=imagerotate *
Rotate one or more images.
Parameters:
rotation - Degrees to rotate image clockwise
One value: 90, 180, 270
token - Edit token. You can get one of these through action=tokens
Example:
* action=revisiondelete *
Delete/undelete revisions.
Parameters:
type - Type of revision deletion being performed
target - Page title for the revision deletion, if required for the type
ids - Identifiers for the revisions to be deleted
hide - What to hide for each revision
show - What to unhide for each revision
suppress - Whether to suppress data from administrators as well as others
One value: yes, no, nochange
Default: nochange
token - A delete token previously retrieved through action=tokens
reason - Reason for the deletion/undeletion
Examples:
*** *** *** *** *** *** *** *** *** *** *** *** *** *** Permissions *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* writeapi *
Use of the write API
Granted to:
all, user, bot
* apihighlimits *
Granted to:
bot, sysop
*** *** *** *** *** *** *** *** *** *** *** *** *** *** Formats *** *** *** *** *** *** *** *** *** *** *** *** *** ***
* format=json *
Output data in JSON format
Parameters:
callback - If specified, wraps the output into a given function call. For safety, all user-specific data will be restricted.
utf8 - If specified, encodes most (but not all) non-ASCII characters as UTF-8 instead of replacing them with hexadecimal escape sequences.
Example:
* format=jsonfm *
Parameters:
Example:
* format=php *
Example:
* format=phpfm *
Example:
* format=wddx *
Output data in WDDX format
Example:
* format=wddxfm *
Example:
* format=xml *
Output data in XML format
Parameters:
xslt - If specified, adds <xslt> as stylesheet. This should be a wiki page in the MediaWiki namespace whose page name ends with ".xsl"
Example:
* format=xmlfm *
Parameters:
Example:
* format=yaml *
Output data in YAML format
Parameters:
Example:
* format=yamlfm *
Parameters:
Example:
* format=rawfm *
Parameters:
Example:
* format=txt *
Example:
* format=txtfm *
Example:
* format=dbg *
Example:
* format=dbgfm *
Example:
* format=dump *
Example:
* format=dumpfm *
Example:
* format=none *
Output nothing
Example:
*** Credits: ***
API developers:
Victor Vasiliev
Bryan Tong Minh
Sam Reed
</error>
</api>
